I want to compare two datatables based on Emp-Id from both datatable and if match found then want to update “EmpName” and “role” column from Dt1 with matched column “Name” and “Role” from Dt2 else update columns as “NA” in Dt1.
Take filter datatable activity, filter based on ID and Role
If filter result has rows then update the DT1 columns by assign- activity
Assign - CurrentRow(“ColumnName”)=DT_FilterResult.Rows(0)(“ColumnName”).ToString
After loops ends DT1 would be updated as per the requirement
prepare an empty target datatable with build datatable, configure the cols:
EmpId EmpDesignation EmpGroup EmpName Role
use var name dtTarget for this
or clone dt1
Assign Activity
LHS: dtTarget
RHS
(From d1 In dt1.AsEnumerable
Group Join d2 In dt2.AsEnumerable
On d1("EmpId").toString.Trim Equals d2("ID").toString.Trim Into gj=Group
From g In gj.DefaultIfEmpty
Let ra2 = If(isNothing(g), New Object(){"NA","NA"}, g.ItemArray.Skip(1).toArray)
Let ra = d1.ItemArray.Take(3).Concat(ra2).ToArray
Select r = dtTarget.Rows.Add(ra)).CopyToDataTable
Kindly note: LINQ is written for the given datatable structure from above
this LINQ query can be used to achieve your desired result.
Use assign activity for the below query.
(From a In dt1.AsEnumerable
Group Join b In dt2.AsEnumerable On a(0) Equals b(0) Into grp = Group
From g In grp.DefaultIfEmpty
Select row = {a(0), a(1) ,a(2),If(isNothing(g), “NA”, g(1)),If(isNothing(g), “NA”, g(2)) }
Select dtFinal.Rows.Add(row)).CopyToDataTable
I have one excel sheet with given data, and want to perform some activities without loop as it contains more than 40000 data and multiple columns also.
Sheet data:
EmpId EmpName EmpGroup EmpDesignation Remark
1 ABC A HR
2 bcd A TL
3 thg B Dev
4 uth D Dev
5 ikhf C HR
6 tppl B HR
7 artu B TL
8 vbnd N TL
9 okjd G PM
10 mnbd C HR
8 jkh N TL
5 kopt C HR
Activities need to perform without loop:
Remove duplicate rows on the basis of EmpId column i.e. if more than 1 EmpId found the only keep 1 row and remaining duplicate rows should be move to other sheet (" Duplicate values")
For given example:
Duplicate sheet will be-
8 jkh N TL
5 kopt D HR
Filter EmpGroup with value ‘D’ and update Remark as “group D”
Note: data is more than 40000 and i want all data after filtering and updating not just filtered datatable.
2 bcd A TL
3 thg B Dev
4 uth D Dev group D
5 ikhf C HR
6 tppl B HR
7 artu B TL
8 vbnd N TL
9 okjd G PM
10 mnbd C HR
Then again for same datatable filter if EmpDesignation is ‘TL’ and
EmpGroup ks not ‘N’ then update Remarks column as ‘group B’
Output:
1 ABC A HR
2 bcd A TL group B
3 thg B Dev
4 uth D Dev group D
5 ikhf C HR
6 tppl B HR
7 artu B TL group B
8 vbnd N TL
9 okjd G PM
10 mnbd C HR
Then again check if EmpDesignation equals ‘Dev’ and Remark is blank then update Remark column as “Other employees”
1 ABC A HR
2 bcd A TL group B
3 thg B Dev Other Employees
4 uth D Dev group D
5 ikhf C HR
6 tppl B HR
7 artu B TL group B
8 vbnd N TL
9 okjd G PM
10 mnbd C HR
I want to perform those actions without loop and with minimum datatables. This is just sample data for logic, data can be more than 40000 and with more than 20 columns.
Basically it should filter and update data but return whole datatable after output not just 1 datatable for 1 filter then perform other filter on that filtered which is wrong.
i need to compare two datatables with same column for example-
DT1
name id
rajkumar
shahrukh
vijay
sreeram
guru
DT2
PatientName ID
Raj kumar
Sree ram V
Guru V
Vijay T
i need to match the name columns of both DT and if the name contains any one of the word in patient name then it should be matched and give the output in a new column as matched
