Hi Team,
How to compare 1st column value to 2nd column value and find the greater value (integer)?
How to compare 2 column in excel and find whether given integer value is not equal to given other column integer value?
Thanks,
Riya
Hi Team,
Thanks,
Riya
Hi @Riya_Sharma !
To do so, we first need to
Here is a concrete example with a dummy excel file:
a.xlsx (9.3 KB)
Compare_two_columns.xaml (12.2 KB)
If the explanation is not clear, let me know !
Hi @Hiba_B ,
I have tried the same,but it’s not working .
In my case I need to compare 2 column of excel and need to check whether value is equal to or not if value is not equal then need to write that value.
2)check whether 1st column has a value if yes then need to check the 2nd column value if it is blank then need to write that 1st column value.
Thanks
Hi !
May you send me your xaml file and an excel with dummy data so we could look at it ?
Hey @Hiba_B ,
I am also having the same issue .please refer below table for ref:
Item A | Item B |
1 | |
2 | |
4 | 4 |
6 | 5 |
9 | 8 |
8 | |
2 | |
2 |
So from above table I have to compare item A col to item B col.
if value is not equal for eg in 1st row we have ‘1’ value in item A col but there is no value present in Item B col.So in that I have to type that value.And in 4th row we have ‘6’ value present in Item A col and ‘5’ in Item B col so that means it’s not equal so in that also I need to type that val.
Thanks.
Okay thank you this is better explained. What happens if column A value and column B value are empty both ?
Ok here is another suggestion:
Input:
Output:
Is this the expected output ?
Here is the code associated: Compare_two_columns.xaml (13.1 KB)
