all column 1 values should be less than column2 and return Boolean value
Try this
isAllValuesless =DT.AsEnumerable().All(Function(row) CInt(row("Column-1")) <= CInt(row("Column-2")))
Cheers!!
Dt.AsEnumerable.All(function(x) Cdbl(x("Col1").ToString) <= Cdbl(x("Col2").ToString))
This gives true if all rows satisfy else false
=> Read Range Workbook
Output-> dataTable
=> Use below syntax in Assign:
Assign-> bool_rows = dataTable.AsEnumerable().Any(Function(row) Convert.ToInt32(row("Column-1")) <= Convert.ToInt32(row("Column-2")))
bool_rows is of DataType System.Boolean.
Hope it helps!!
Assign activity:
ResultBoolean = dt.AsEnumerable().All(Function(row) Convert.ToDouble(row("Column1")) < Convert.ToDouble(row("Column2")))
