Then accordingly u can add
if possible can you please share your suggestion as .xaml will be very helpful and appreciated
Thank you
As i used in previous solution use for those teams for each and then copy that range using read range and then use write range
Ok so i have one confusion while i trying write cell as in my Input file there is no No. of Employees Row but that we need in my OutPut file how can i manage that part because that row i have to put in between the write range
any suggestion
It will be static for all cases ryt? Then whats the pb
