Scenario: When editing selectors to use variables, the text cannot be edited in the edit selector window. It can be worked around by manually editing the selector in the Target>Selector Properties box.
Steps to reproduce: 2
Current Behavior:
Expected Behavior:
Studio/Robot/Orchestrator Version:
Last stable behavior:
Last stable version:
OS Version:
Others if Relevant: (workflow, logs, .net version, service pack, etc):
Hi @samuelmongeau,
If you directly go to the Target=>Selector=> and click on the expand button you will get the selector editor window.
In case you want to pass variables, it should be opened in attribute editor window.
To open that,
just modify the value of the selector (_at least something in the selector value,by using your arrow keys to navigate. You can insert ‘“+ +”’ and come out.), after that click on expand button and you will be able to open in attribute editor.
