hi all
What is the actual difference between write cell and write range and where we actually use them.
- Write range as name suggest is to write a datatable to excel input multiple cells
- Write cell is to write a string or integer to a specific single cell in excel
Hope this helps
Write Cell: The “Write Cell” activity is used to write a single value to a specific cell in an Excel spreadsheet. This activity is typically used when you want to update or input a single data point into a specific cell, such as updating a particular value in a specific row and column of an Excel sheet.
Write Range: The “Write Range” activity is used to write a range of data (multiple rows and columns) to a specific range in an Excel spreadsheet. This activity is commonly used when you want to update a larger set of data or replace existing data in a specific range.
Hi
Write cell is used to write a single value in a particular cell
Write range is used to write entire datatable into the specified excel sheet
Write Range - The write range activity used to write the datatable to the excel. You can also specify the range of the excel to write in the excel sheet. There is two activities for write range is workbook and excel activities they are Write range workbook and write datatable to excel.
Write cell - The Write cell activity is to write the value in the specific cell in the excel. This also have workbook and excel. One is Write cell workbook activity and write cell in excel.
Hope it helps!!
