As mentioned in the Automation Express Documentation, Automation Express grants limited access to only StudioX and Studio Web, I hope to know that what are the exact difference of StudioX and Studio Web using Automation Express license and Community License.
These are the Differences between Automation Express License & Community Licence
Automation Express License: The Automation Express license typically offers more advanced features and capabilities compared to the free Community License. It might include additional functionalities, premium support, and more flexibility in terms of scaling and deployment. Users with this license might have access to priority support, advanced features, and integration options, making it suitable for businesses with more complex automation needs.
Community License: The Community License is a free option provided by UiPath to help individuals and small teams get started with automation. While it provides access to UiPath StudioX and other UiPath tools, it might have limitations in terms of support, advanced features, and scalability. It’s generally suitable for personal projects, learning, or smaller-scale automation initiatives.
Hope It Helps
If you have found my solution helpful kindly mark as Solution
Thanks @vinitha_yachamaneni
May I know, exactly what are the additional functions that Automation Express have but the Community version does not have. Because I feel like all the activities usage are still the same.
Hi, I have already read the two links, but it never specify what are the exact difference using StudioX and Studio Web under the two types of license (Community and Automation Express license)
@Anil_G Thanks for the reply.
So is it correct to say that generally, in terms of constructing workflow using StudioX and Studio Web, there is no difference between community and Automation Express?
For updating, I check the Automation Express license documentation , it mentions that “for the Automation Express group. It is automatically set to Latest version , and cannot be changed”. Does this mean, it is same as community as we are forced to use updated version?
Hi, I have read this documentation, however, i did not identify any Premium Support, Enhanced Security Features, Advanced activities and integrations mentioned inside. In fact, StudioX is more restricted as it only allows usage of StudioX and Studio Web. Also, if I use free licensing Automation Express, I also do not have UiPath Support, No security options…
Free and community does not have support …if you take a license then you have support …
And coming to latest version…community and free plans are on latest preview versions and licensed automation express would be on stable latest version
Hi Vinitha - i have been following the automation explorer class (from UiPath) and now in the middle of the associate developer class, with a Free license - but 60 days have passed and i now have been bumped to a community license, and I struggle with licenses not available anymore for mu automation scripts (which are currently all attended scripts) .
My first question - reading your input here - can I continue with Studio or do i need to switch to Studio X ?
