Difference between clik and check activity for Radio Button
I have to select Radio Button for Male or Female
Used Check and Click Activites for selecting Male or Female.
Its Working fine. But I didnt get the difference between Click and Check activity for selecting Radio Button.
The Check activity should be used for checkboxes where it can be toggled between check and unchecked.
Radio buttons are different though and you can’t uncheck it when you click on it; they only get unselected when you select a different radio button within the group. Click should be used for Radio buttons, in my opinion. Technically, you could use whatever works for the user interface that you are interacting with, though.
Regards.
Hi Clayton,
Thank u for clarifying my doubt.
Have a great day.
