What is the difference between Anchor base, Read PDF activity and OCR?. I knew that OCR can be used to read and locate in the image based files but remaining 2 can read only PDF files, so i just want to get clear picture about these 3 in terms of file handling and features.
Anchor base : is used to get a specific value and this activity can be used if that value we want has a anchor or solid element or image near to it, so tthat we can keep that an anchor and get the value we want
READ PDF - this is used when pdf has no image that is pdf is native pdf…
READ PDF OCR - sometimes pdf will be in image format with text in it so we need to use OCR to read them
Read PDF - this activity will be used to read data from Excel file.
Anchor Base - A container that searches for a UI element by using other UI elements as anchors. This should be used when a reliable selector is not available.
