Hi All,
I’m trying to select one item from a shopping website using Data Scraping. But indicator is selecting whole web page.
Please Help me with what settings to make.
Thanks in Advance.
Hi All,
Thanks in Advance.
Try to use table extraction for scraping data
Hello @Vaishnav_Tej
Can you double check once whether have you installed the uipath extension?
Regards
Sudharsan
Hello @Vaishnav_Tej
Are you using chrome browser? Can you plz confirm the chrome extension is installed in the studio?
If yes, plz reintall and check it once.
Thanks
