Cloud Project questions/problems
Hello guys. Can somebody please tell me how to remove my project from cloud?
I use one project on 3 different computers, and everytime the project locks. Sometimes it syncs and i loose my updates made for the specific PC. Thanks :slight_smile:
Btw, what are the benefits of the cloud Project anyways?
Hi @Povilas_Jonikas
Can’t always be fully disabled on existing projects. the easiest fix is to create a new local project. copy your files from the cloud project folder to the new local folder. open the new project as a local project in studio. work on this local project to avoid cloud locking and sync issues.
or You can use Git.
For more:
If helpful, mark as solution. Happy automation with UiPath
Tanks for the answers @prashant1603765 :slight_smile:
