How to convert studio web project to only studio project
Hi Team,
Is there a way to migrate a Studio web project to a Studio-only project?
The user no longer wants to sync and use the web version.
Thank you
Hi @tejaskumar.darji ,
Yes. If the project was originally created in Studio Web, there is no direct conversion option to change it into a Studio-only project.
Try this approach:
  1. Open the project in UiPath Studio Desktop (if supported).
  2. Save/publish a local copy to your machine or source control repository (Git, Azure DevOps, etc.).
  3. Stop using Studio Web for future development.
  4. Continue maintaining the project only from Studio Desktop.
  5. If some Studio Web-specific activities are used, you may need to replace or redesign them in Studio Desktop.
Thanks
Yes, you can download/clone the Studio Web project and open it in Studio Desktop, provided the project dependencies are supported.
After opening it in Studio Desktop, save it as a local project and the user can continue working without syncing with Studio Web.
Just make sure any Studio Web–specific activities or features are supported in Studio Desktop.
Okay but how to - save it as a local project?
Could you provide the steps and menu options to do the same
You can do it from Studio Web by opening the project and using Download / Download project (if available). This downloads the project files as a ZIP.
Then in Studio Desktop:
Open Studio Desktop.
Select Start → Open → Local Project.
Extract the downloaded ZIP and select the project folder/project file.
Save the project locally.
After that, you can work on the project in Studio Desktop without syncing it with Studio Web.
The exact menu name can vary depending on the Studio Web/Studio Desktop version.
