Click Check Box Problem
Hello everybody, i have an issue that i can’t solve, can somebody help me?
I want to click robots check box but robot name is variable that read from excel so it can be change. I have no idea how to do it
I mean i read from excel with read cell and store it inside Generic Value variable type.
If you need any information let me know.
Hi @berkay
Click on robot 5 and then use uiexplorer to find the selector based on that u can get the property as idx check each and every check box selector and iterate based on count
If click not working use check activity
Thanks
Ashwin.S
Hi @Ashwin thanks for your reply but can you please describe more spesificly. You mean i wont use ‘robotName’ variable? Or can you upload workflow?
This is what i see when i clicked ROBOT5 and open uiexplorer;
html title=‘Jobs - UiPath Orchestrator’ />
<webctrl isleaf=‘1’ tableRow=‘2’ tag=‘TD’
I think i have to add my variable somewhere
Hi @berkay,
Try to take a look at the new Selector learning path
https://360.articulate.com/review/content/7abbfef3-efab-44d2-9289-bda8e5b7fd34/review
Look under “Difficult Situations”
So find a Anchor point, using your variable.
You can insert your variable by clicking ctrl+space, when editing your selectors.
Hi @berkay
Don’t give string variable set it as int variable check it for other robot s and ensure the selector are different based on table row and column
Thanks
Ashwin.S
Okay thank you for your reply!
