Have made the changes to Variable and Aurguments in Variable and Aurgument Panels but changes not reflecting in the activity even after refresh, but while invoking workflow inside others the changes are reflecting in Aurguments panels, the project is connected to tfs,is there anyone who can help.
Do you mean the uppercase change? That the variables has the same name but you have changed from lowercase to uppercase and vise versa?
That kind of change does not sync. Just make a change with a new letter or such and change back and the changes will be visible.
Hi @saahil.shaikh
Replace the argument with a different Name.
Cheers,
Thanks for your reply Guys Apprciae your efforts
