i want to capture data from a site where same named ui element are there and the ui elemnt i want to capture changes each time for different entry, For ex: co-payment is ui element name but there is another co payment named ui element and some times its on the first no. and sometimes its on mid or last , So how can i capture that element from that site
Do u mean the selector uielement having name as co-payment or co payment but it’s position changes
nived ui eement name is co payment and there is another section which has same co payment name tag, and also these section changing there position
It would be great you can share the screenshot of the elements
Also share the selectors which you are targeting the element
By this way we can get to know the issue
Thanks
What I am suggesting go with css selector concepts because they use the unique part of uielement for detection
i have tried anchor base find children and using wildcard too but its not working
sorry the project im working on is credential work and my office will not allow to take screenshot ,
i can navigate you through that if you want
Check the difference in the selector of both elements
even if the position changes, the selector has to be dynamic
Hope this may helps you
Thank you
yes the selector is dynamic and i have tried three methods for that using idx as wildcard and anchor base and also find children method none of them is working , if someone can help me with visual tree method or fuzzy search method
