but the message is not displayed
in the field ‘in emails from’ you are giving mails does mails variable contain any mails in it?
ideally you can provide like this Gmail.Folder("Inbox")
cheers
Try like this:
In for Each Email give the below condition:
Click on + button=> Pop will appear=> Hover to Gmail=> You will get list of folders available. You can specify which folder you want.
In message box give this:
"The message is "+CurrentMail.Subject
Refer the below image for better understanding.
Hope it helps!!
no need no mention any folder.
you need to click on + button, it will display all the folders which you have in the mail
Thank you shiva. This helped.
Thank you Parvathy this helped.
Thank you Anil,this helped.
