Basic get data from excel and input in webform help
Hi all,
I’m having a problem getting started with this basic operation because the only documentation I can find seems to be out of date:
This tutorial appears to be for Studio rather than StudioX, and the workflow doesn’t match what is available to me in StudioX.
Once I get to the For Each Row in Data Table step seen at 2:38, I am unable to proceed because my StudioX functionality is different as seen here:
Any help would be much appreciated.
@mjoseph74,
I don’t have StudioX to check if For Each Row in Data Table activity but you should be following this documentation to get data from excel file and iterate through all the rows.
Thanks for this guidance. Is there any documentation for StudioX with instructions on how to get data from excel and input it into a webform? I can’t seem to find any documentation that shows this workflow.
nevermind for now. I found this template within StudioX and I will try it:
