Automation Hub - Automation Export
Within Automation Hub, it would be beneficial to export all ideas, or a subset based on filters, that includes all the data regarding the idea, not just the data that’s visible within the table. Specifically referencing the page under the Explore → Automations.
Thank you for your suggestion. I added it to our internal ideas tracker for our team to consider.
Hello @hubs032,
When we are going to have the Open API, you will be able to export more data related to the automation idea.
Also, make sure to check the new columns added in the Automation Pipeline.
Thank you,
Iulia
An old post I know, but if anyone searches and finds this thread, you can export using download CSV from the workspace area
