Assign: Conversion from string "11/08/2022 00:00:00" to type 'Double' is not valid
Dear All,
Possible to get this resolved with expression editor?
Assign: Conversion from string “11/08/2022 00:00:00” to type ‘Double’ is not valid.
Thanks.
HI @Alfred_Gan
Instead of Cdbl(x("Column name").Tostring)
Try with this expression
DateTime.ParseExact(x("Column Name").Tostring,"dd/MM/yyyy hh:mm:ss",System.Globalization.CultureInfo.InvariantCulture).ToString("dd/MM/yyyy hh:mm:ss")
Or
You can try with this also
CDate(x("Column name").Tostring)
Regards
Gokul
Hi @Gokul001
i tried but have error.
OutputData.AsEnumerable.Where(Function(x)Date.FromOADate(CDate(x(“DATE”).ToString) = Now.Date).Select(Function(x)x(“JOB NO”).ToString).ToArray
OutputData.AsEnumerable.Where(Function(x)Date.FromOADate(DateTime.ParseExact(x(“DATE”).Tostring,“dd/MM/yyyy hh:mm:ss”,System.Globalization.CultureInfo.InvariantCulture).ToString(“dd/MM/yyyy hh:mm:ss”) = Now.Date).Select(Function(x)x(“JOB NO”).ToString).ToArray
Either way have error…guess i does it wrongly
Hi @Alfred_Gan
Try like this expression
Dt1.AsEnumerable.Where(Function(x) (CDate(x("DATE").ToString) = Now.Date)).Select(Function(x)x("JOB NO").ToString).ToArray
Regards
Gokul
Alternative expression @Alfred_Gan
Dt1.AsEnumerable.Where(Function(x) (DateTime.ParseExact(x("DATE").Tostring,"dd/MM/yyyy hh:mm:ss",System.Globalization.CultureInfo.InvariantCulture).ToString("dd/MM/yyyy") = DateTime.Now.ToString("dd/MM/yyyy"))).Select(Function(x)x("JOB NO").ToString).ToArray
Regards
Gokul
Hi @Gokul001 ,
It works! thank you!
