We are using this code to sum up a column value but are getting this exception
Conversion from string to type ‘Double’ is not valid.
Code Used
((CDbl(((dt_data.AsEnumerable.Where(Function(x)x(“Group account”).ToString.Equals(“680”)).Sum(Function(x)CDbl(x(inconfig(“Month_Column”).ToString).ToString))).ToString))*(-1)).ToString)
The Month Column the values are present in Below Format
2.29.319,00
8.89.616,88
62.66.662,88
Since the month column data contains characters like . and ,, the exception will be thrown by the target of an invocation. You can try using the following query for the same operation:
How can we incorporate it into this code
Have tried the method you suggested by incorporating it in into the above code but that was not giving the output
(From d in dt_data.AsEnumerable
Where d("Group account").ToString.Trim.Equals("680")
Let sv = d(inconfig("Month_Column").ToString).ToString.Trim
Let dv = Double.Parse(sv , System.Globalization.CultureInfo.CreateSpecificCulture("de-DE"))
Select x = dv).Sum(Function (x) x)*-1
we do have a set of options in place when parsing string to double. But we dont know what exactly you have done, facing which error and what for values are processed.
So we would recommend to more analyse the root cause as given options where proofed e.g. within immediate panel success check
To overcome this issue, you need to remove the thousands separators and replace the decimal separators with a period (“.”) before converting the values to double.
Here’s an updated version of the code that incorporates these changes:-
((CDbl(dt_data.AsEnumerable.Where(Function(x) x(“Group account”).ToString.Equals(“680”)).Sum(Function(x) CDbl(x(inconfig(“Month_Column”).ToString).ToString.Replace(“.”, “”).Replace(“,”, “.”))))*(-1)).ToString)
