I followed the instruction to create a sequence called “System1_NavigateTo_WIDetails”, but some problem occurred.
1.The argument “in_WIID” is disappeared after invoke workflow, as a result, in Activity Navigation To, it is said that “in_WIID” is not declared(I use Chinese version, and I’m not sure if I use the correct vocab).
2.Click the Import Arguments of origin Invoke Workflow File, there is only the in_System1_URL.
3.If I ignore these two problem, copy the invoke workflow file in Process, Import Argument , and run Main.xaml(I have finish remaining instruction) This error message showed up, and the program loop for login.
Do you have ideas?
