Using Regular Expression to find value between string and first comma
I am trying to extract data off a pdf. I’ve taken all the spaces out of the PDF to make sure there aren’t double spaces by accident. I’ve written this so far
System.Text.RegularExpressions.Regex.Match(Spaceless,“(?<=customerresidingin).+(?=,)”).ToString
In one example (unfortunately i can’t provide examples due to sensitive nature) it pulls in the correct information from the string customerresidingin until the first comma however in another example, it pulls the data until the 2nd comma. How do I correct this?
Correct:
Incorrect:
Hi, Atarantino
You can just split the string:
string.split(","c)(0)
This way, if text has comma, the expression return text before. If no, return all text in 0 index position
So simple - thank you for the quick response this was exactly what I needed.
Hello
Already solved but thought I would respond anyway :slight_smile:
Take a look at this Regex pattern:
Steve
