Hi Guys
I am unable to connect to Database and manually too but able to connect to SQL DB using same credential when I am running as a different user.
For example when I login SQL as different user and use the credential I am able to connect to the DB, but when I am opening SQL as normally and using same credentials to connect to the DB. I am getting login failed to server
similarly not able to connect to using UiPath DB activity.
Hi!
What version of the DB activity and what provider name are you using?
Could you give us the connection string as well?
And what is the error message?
I am using connection wizard
Data provider : SQL server
Database UiPath package version : 1.9.0
SQL management Studio : 20.2
Error : Login Failed for user “user name”
Strange part is I am getting same issue in SQL server but when I login into SQL application through different user option using same credentials I am able to connect to DB.
@Akshay_Suryawanshi,
Most likely issue of SQL User policy. Check if any restrictions or differences for this particular user. You may try creating another user and check.
I am using the same credentials for both. What to check in user policy?
I was asking due to this.
Yup. What shall I check in the user policy?
