Database connection Issue. On system am able to connect the DB and able to execute query but getting an issue when i am going to connect DB using studio
I am able to connect the database and also i am able to execute the query but when i am making connection using UIPath i am betting this error “Connect: Cannot open server “pearce-services.com” requested by the login. The login failed.”.
How to resolve this.
Hello @Puneet_Singh3
You can connect with SQL Server, i did connect and succelful
Hello @minhduc
I used that only. see
I try case of you using and it working good.
You can check again name server, port of server connect and user have correct ? If you no is configure SQL Server please contact with configure person
Please check this is my azure active directory connection.
You chose sql authentication and not AD…
Hi @Puneet_Singh3
Same issue i have faced previously
I have tried to solve this by many ways and also i have uninstall the UiPath once to check if it works but der was some issue with SQL Server Management Studio.
Once i then tried uninstalling the SQL Server Management Studio by taking backup of db’s and install it again then it starts working fine
Happy Automation :raised_hands:
Best Regards
Er Pratik Wavhal :robot::man_technologist:t4: :computer:
Done bro…working fine now thanks
Hi @Puneet_Singh3
Any other solution you did or by reinstalling it started working ??
Mark as solution and like it if above solution helps you. :slight_smile:
Best Regards
It just issue with the connection string.
hi @Puneet_Singh3
So may i know what did you do to solve it ??
Best Regards
