UIPath Test Suite for our test automation project
Hello everyone. We would like to use UiPath Test Suite for our test automation project(Desktop, Web, API ect…). Do we also need Unattended Robots? UiPath test suite has the automation Ops components?
Hi @amel237
To effectively utilize UiPath Test Suite in test automation projects, you’ll need
a UiPath Orchestrator instance,
a Test Manager license, and
potentially a Tester - Named User license
Additionally, familiarity with UiPath Studio and its automation framework is beneficial.
Automation ops is a separate feature so will need to get additionally.
Regards
Sonali
Do you need Unattended Robots for UiPath Test Suite?
No, you do not need Unattended Robots for running test cases in UiPath Test Suite.
UiPath Test Robots are separate from Unattended Robots. When you use the Test Manager, Orchestrator, and Test Robots, you can run automated tests (Desktop, Web, API, etc.) without requiring an Unattended Robot license. UiPath provides a specific license type called Test Robot license, optimized for test execution (parallelism, faster feedback loops, etc.). These Test Robots are used in conjunction with Test Sets in Orchestrator and can be triggered via CI/CD pipelines or manually.
Does UiPath Test Suite include Automation Ops components?
UiPath Test Suite and Automation Ops are separate offerings in the UiPath ecosystem.
UiPath Test Suite is for test automation, including:
  1. Building and executing automated tests (desktop, web, API, mobile)
  2. Integration with Test Manager, Orchestrator, and CI/CD
  3. Managing test data, test sets, test results
UiPath Automation Ops is part of UiPath Automation Cloud, focusing on:
  1. Policy management
  2. Managing extensions, governance, and compliance
  3. Centralized control over Studio, Assistant, and other tools
hello @Gauri_Kelo,
thank you very much for the detailed feedback. what is the difference between UiPath Automation Cloud and UiPath Test Suite?
thank you very much for the feedback. I have the following questions:
with UiPath Test Suite, Can i create a Queue Trigger to run a Testautomation?
How can I test UiPath Test Suite for free? We currently use the UiPath Community License for evaluation.
