Athul_A_k
(Athul A k)
1
Hi everyone,
I’m encountering an issue while using the new UI Agent activity in UiPath Studio. When I run the automation, I receive the following error:
UI Agent: Error generating actions: UiPath LLM execution not permitted..
Please try again later and/or update your prompt, if needed.
License Type: [Community ]
@Athul_A_k
Can you try to look on below licensing documentation, it may help you to get idea on your issue
Yoichi
(Yoichi)
3
According to the following document, UI Agent public preview is provided to Enterprise customer and probably community user cannot use it, I guess.
@Athul_A_k
If you find it helpful, please mark the post solution to close this topic.
Happy Automation!!
