Am trying to him resolve the issue
No @Nithinkrishna still struck on the same issue. Tried to add external application also. even though not able to get what I want.
Hey @logesh_kumar1
So you are stuck at the External application right ?
Kindly refer this - Managing external applications
Thanks
#nK
Hey @logesh_kumar1
So as discussed the below points,
- Make sure the External application is registered as Confidential app
Ref - Managing external applications
- The endpoint and the body should be properly formed with client credentials as grant type
Ref - Accessing UiPath resources using external applications
- Then with the Access token we can do the requests to any of the UiPath Orchestrator resources (provided the scopes are properly applied in the Authorization request)
Hope that helps
Thanks
#nK
Hi @Nithinkrishna is there any possibilities to make auth token to not expired or increasing expiration time of auth token?
You can’t make it longer as that will cause security concerns.
