Hi all,
i need to manage multiple credentials and doing some operation inside, so log in with credential 1, do operations, log out, log in with credential 2, do operations, log out, log in with cred 3…etc.
I was thinking to use a flow switch activity, can you confirm that it can handle at least 11 cases? (so, in my case 11 credential and apps?)
In this case, which is the best solution to manage that if i have more than 11 credentials?
Hi
We can handle this with a LOOP like WHILE LOOP either if we have all the credentials stored in a array or list variable
Did we try that
Like with condition Counter < listvariable.Count
Where counter is a variable of type int32 with default value as 0
So that we can access each credentials with the index value counter and increment counter atlast with a assign activity like this Counter = Counter + 1
Unless we don’t need to use multipl credentials and work upon a credentials on any condition then we can surely go for SWITCH CASE
THATS A GOOD CHOICE INDEED
if i understand listvariable is an array with value credential1,credential2,credential3, ecc.
and i use the counter like the index array.
My problem is: when i log out, i should be able to reconnect to another app, (so different selector) is possible to handle this case in a while loop?
And i’m using reframework, so eventually my idea is to delete getTransaction state and put all the while loop with operations inside process state, what do you think about this solution?
I have 15 different credentials and 15 different apps to connect, the mechanism is:
-I take credential 1, log in to app 1, managing some orders and log out
-I take credential 2, log in to app 2, managing some orders and log out
-I take credential 3, log in to app 3, managing some orders and log out
and then until credential 15… When i finish credential close all.
yah got it
that would work
we can pass the credentials from a collections variable and iterate through WHILE loop with a SWITCH activity in it
–that switch activity will take us to the case based on the input passed, and process based on the login credential passed
