Dear UiPath friends!
I am currently breaking my head over the error below.
What I want:
- Retrieve information from a website percentage (as a String) that could be positive and negative (for example 0,08 or -0,05);
*Write it to a dt column so I can reuse the information easily for a further analyses; - Get the information from the dt and assign a value to another column based on the result of the above mentioned value (string) using a If statement activity.
Other info:
- I do not have this issue when I write the information into the dt myself.
- This is how I get the information:
Error:
Source: Assign 5 min
Message: Input string was not in a correct format.
Exception Type: System.FormatException
RemoteException wrapping System.FormatException: Input string was not in a correct format.
at System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt)
at lambda_method(Closure , ActivityContext )
at Microsoft.VisualBasic.Activities.VisualBasicValue1.Execute(CodeActivityContext context) at System.Activities.CodeActivity1.InternalExecuteInResolutionContext(CodeActivityContext context)
at System.Activities.Runtime.ActivityExecutor.ExecuteInResolutionContext[T](ActivityInstance parentInstance, Activity1 expressionActivity) at System.Activities.InArgument1.TryPopulateValue(LocationEnvironment targetEnvironment, ActivityInstance activityInstance, ActivityExecutor executor)
at System.Activities.RuntimeArgument.TryPopulateValue(LocationEnvironment targetEnvironment, ActivityInstance targetActivityInstance, ActivityExecutor executor, Object argumentValueOverride, Location resultLocation, Boolean skipFastPath)
at System.Activities.ActivityInstance.InternalTryPopulateArgumentValueOrScheduleExpression(RuntimeArgument argument, Int32 nextArgumentIndex, ActivityExecutor executor, IDictionary2 argumentValueOverrides, Location resultLocation, Boolean isDynamicUpdate) at System.Activities.ActivityInstance.ResolveArguments(ActivityExecutor executor, IDictionary2 argumentValueOverrides, Location resultLocation, Int32 startIndex)
at System.Activities.Runtime.ActivityExecutor.ExecuteActivityWorkItem.ExecuteBody(ActivityExecutor executor, BookmarkManager bookmarkManager, Location resultLocation)
β End of stack trace from previous location where exception was thrown β
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at UiPath.Executor.BaseRunner.EndExecute(IAsyncResult result)
at UiPath.Executor.InProcessRunner.EndExecute(IAsyncResult result)
at UiPath.Core.Activities.ExecutorInvokeActivity.EndExecute(AsyncCodeActivityContext context, IAsyncResult result)
at System.Activities.AsyncCodeActivity.System.Activities.IAsyncCodeActivity.FinishExecution(AsyncCodeActivityContext context, IAsyncResult result)
at System.Activities.AsyncCodeActivity.CompleteAsyncCodeActivityData.CompleteAsyncCodeActivityWorkItem.Execute(ActivityExecutor executor, BookmarkManager bookmarkManager)
I have tried changing the culture without any succes. Can somebody please please please help me out?! Thank you in advance!
Kr, NotARobot
