When I try to use the split function I find it has two different errors that pop up. One is in the textbox of the assign I call it in and it says “‘Split’ is not declared. It may inaccessible due to its protection level.” And then there is another on the top of the assign activity that says “Cannot assign from type ‘System.Object’ to type ‘System.String’ in Assign activity”. The splits were working fine in the past then all of a sudden this happened and I do not know how to fix it.
My assign activity is
string_split = Split(string, “,”)
I tested it again in another file and had it not throw an error immediately, I ran it once and then when I went back to the assign it would have the errors again.
Worked like a charm, cheers!
