I’m reading a text file which has XML contents
I mean it is XML file saved with .txt extension for readability.
I have to read only some parts of the whole file.
Does any one know how to clean the XML file for the desired contents?
@ray_sha
as it is XML Retrieval via the provided XML Apis can help to do it with minimal effort. Sharing of representing sample data will help us for further solution suggestions.
@ray_sha
Perfect.
A good pattern here in the forum is: showing input (is done above), giving expected output sample with a clear description and then we can setup a individually solution approach very fast.
@ray_sha
with the UiPAth.WebAPI.Activities Package we do get some activities to read in XML text into a so called XDoc. With the methods from System.Linq.XML namespace we can use several methods for XML Processing:
In your case you want to remove the header/Prolog and 1 tag. Still same recommendation: Can be done the regex replace.
