Can I run bot in two different machine same time ,with same robot account, where two machine have different credentials.
Yes.
Any of the below combinations work.
Same robot account on 2 different machines. But credentials cannot be different. Credentials are account specific not machine specific. If you have different credentials then it is different bot accounts.
Different robot account on same machine if your machine allows multiple logins at the same time.
Welcome to the community
Same account cannot be used at same time..different times you can
If credentials are differents its two accounts on wither two machine or one machine(if supported hd bots) would work.assuming you have two licenses in plce
No, same robot account cannot run on two machines at same time.
Each robot session is tied to one machine and one credential per run.
Use separate robot accounts or unattended licenses for parallel execution.
If you found helpful please mark as a solution. Thanks
Happy Automation with UiPath
