I am trying to make a POST call in UiPath. Following is the body that I am passing:
But it is throwing following error:
"{\"type\":\"https://tools.ietf.org/html/rfc7231#section-6.5.1\",\"title\":\"One or more validation errors occurred.\",\"status\":400,\"traceId\":\"00-2fe623da09af2e429f75d174981c568b-567cb59d5693eb4f-00\",\"errors\":{\"$\":[\"'l' is an invalid start of a value. Path: $ | LineNumber: 0 | BytePositionInLine: 0.\"]}}"
In Postman this error comes when there are no quotes around the request body for instance:
I tried passing the request body as well but no progress.
Can anyone help me with a solution?
Anil_G
(Anil Gorthi)
February 13, 2023, 10:44am
2
Umer_Shahid:
request
@Umer_Shahid
If you are trying from postman…then there is a option on right top of postman which will give you the curl url…you can paste it directly in the UiPath studio activity wizard to get the request populated properly
cheers
Can you please make a small flow to show? @Anil_G
Anil_G
(Anil Gorthi)
February 13, 2023, 11:06am
5
@Umer_Shahid
Please check this
Click this icon on postman
Then copy the curl
CLick import
Paste the curl there
Output
Remove --Location from curl
curl --request POST 'https://devapi.simplefm.io/api/WorkOrders' \
--header 'Accept: application/json, text/plain, */*' \
--header 'Accept-Language: en-US,en;q=0.9' \
--header 'Authorization: Bearer eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJqdGkiOiJkMWY0OTk0OS1kOTE1LTQ1MjgtOGYzYy05M2UwNzYzNDg4N2UiLCJVc2VySWQiOiIxNjI2NiIsIlVzZXJUeXBlIjoiMSIsIlVzZXJFbWFpbCI6InphaW51bGFiaWRpbmtoYW5AaG90bWFpbC5jb20iLCJDbGllbnRJZCI6IiIsIlBhcnRuZXJJZCI6IiIsIkF1dGhvcml6ZWRSb2xlcyI6IjYiLCJSb2xlQmFzZWRQZXJtaXNzaW9ucyI6IjYsNywzMCwzNywxMiwzMSIsImV4cCI6MTY3NTI3NDM4NCwiaXNzIjoiaHR0cHM6Ly9zaW1wbGVmbS5pbyIsImF1ZCI6Imh0dHBzOi8vc2ltcGxlZm0uaW8ifQ.zZDhu48f8ylSREA42Q9MXlvGeSZsfQsfg97iSokiwRY' \
--header 'Connection: keep-alive' \
--header 'DNT: 1' \
--header 'Origin: https://dev.simplefm.io' \
--header 'Referer: https://dev.simplefm.io/' \
--header 'Sec-Fetch-Dest: empty' \
--header 'Sec-Fetch-Mode: cors' \
--header 'Sec-Fetch-Site: same-site' \
--header 'User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/109.0.0.0 Safari/537.36 Edg/109.0.1518.70' \
--header 'content-type: application/json' \
--header 'sec-ch-ua: "Not_A Brand";v="99", "Microsoft Edge";v="109", "Chromium";v="109"' \
--header 'sec-ch-ua-mobile: ?0' \
--header 'sec-ch-ua-platform: "Windows"' \
--data-raw '{
"locationId": "99643",
"poNumber": "null",
"clientWONumber": "123",
"tradeId": "24",
"priorityId": "2",
"nte": "500",
"cnte": "500",
"description": "test",
"reason": "test",
"clientId": "1252",
"createdById": "16266",
"typeId": "1",
"Flags": []
cheers
Already did it. 400 error is being thrown.
Anil_G
(Anil Gorthi)
February 13, 2023, 11:49am
7
@Umer_Shahid
On Postman you are able to get the response properly?
cheers
Fixed it. Issue was while buidling request body.
