MyFile.xlsx (9.8 KB)
My excel have 2 same ID but description is different and sallery is based on description.
How can i read next row and if it has same ID then write both the first ID and same ID data together into field.
So that I can create one case on user and add both row information into one case.
help please. @ppr@supermanPunch
@Latif If you can provide a Output Excel file for the Sample Input file that you have given, it would be better Otherwise I would have to ask you questions in a repetitive manner.
because i have to use the data into ServiceNow and close ticket if the next row is not same… and if next row is same as current row then I need to append the current row data into same ServiceNow ticket.
So that I do not create a double ticket on person name…
