Hi, I have modified existing test case and again published. New version of package is available in process and new test case also available in orchestrator. But if try run the test case then it failed immediately and getting error. Please find attached screenshot for reference. If I published new package also getting same error. Please help me to resolve it.
Hi go to c:user: your user : nuget
And remove the previous process nuget folder and try again
If u have any other machine
Try to run on other machine as well
Also check. The version of the studio from where this package was published if studio is of higher version then this may cause the issue @baranidharan.gajendran
Thanks @jast1631 . Yes you are right. The studio has upgraded recently but robot not. Now we are uninstalled robot from same machine and installed again. Now test cases are running fine.
