After loading Generating synthetic test data (project) from Application Testing with UiPath Test Suite.
ok after loading this "Generating synthetic test data (project) "project built, I get an error, which would now expect in a tutorial.
Is your project Windows? If so, can you try to add New Object() at the beginning of the expression like New Object() {a,b}
The following post also helps you.
