I am facing this issue after the latest update. The sequences are not opening fully. To see them full I have to double click the sequence heading each time. I am using studio 2021.12.0-beta.7179. Using same issue on two different computers. One computer is running Windows10, while another is Windows11. Both with latest updates. Please refer to the image for the issue.
Hi @Subhrapratim_De ,
A Similar Topic is being discussed below . I have experienced this as well. It is most probably a Bug in the version of the Studio Packages that you are using. It can be solved by downgrading to the latest stable dependencies as mentioned here.
Hi
Welcome back to UiPath forum
Just click once on Expand button that you can see at the right top of the Design panel
Then save it and try accessing it same way you did and see whether it looks fine
Cheers @Subhrapratim_De
Yes…both Win10 and Win11 have same issue.
Done that too. But no luck.
No… Then I have no time for that. Will give it a try and let you know.
As @supermanPunch suggested in the thread, can you downgrade the packages to the stable version and try
Hope this will help you
Thanks
I think the only way is to uninstall and install the latest stable LTS version
It’s a big been cleared in latest version I believe
You try to downgrade the package, As @supermanPunch & @Srini84 suggested
Regards
Gokul
Thanks… Downgrading UiPath.System.Activities to v21.10.4 resolves the issue.
