Problem iterating with a for each loop
Hello to everyone!!
I’m used to working with loops, but this time, something is happening and I can’t understand why.
Here my sequence:
1 - Collecting data from AS400 with this structure:
Converting it into an Array List
Now:
Now I’m trying to iterate over it
The Output is:
Why the name is not coming up?
The message box is only sending to me the variable type.
What I’m missing here?
Thank you
Hi
In the final message box mention as
NomeOutout(1).ToString
We need to mention the index
Cheers @Andre_Vieira
adding toString() to variable of datatype Array(Of xxx) will return the datatype info
In case of you want the to display the content of the array you can do following:
String.Join(" | ", YourArrayVar)
feel free to replace the " | " by any string used as seperator. With Environment.NewLine the items can be seperated within new lines (Linebreaks)
In case of inspection, if the implementation is working as expected we would suggest to work with debuging, brekapoints, locals/watch/immediate panel as trained in the Debugging course from the UiPath Academy
Hello Dear Palaniyappan
I tried it
This is the current output:
Palaniyappan
Ok, is better the receive System.String ahahah
What I’m doing wrong?
Wait
I got it
In the assign just keep like this
Split(item,”:”)
Remove .Tostring
@Andre_Vieira
@Andre_Vieira
as described above
grafik
:sweat_smile:
Aaah
See there are either two way
If you want to keep the NomeOutout as a string then expression should be like this
NomeOutout = Split(item,”;”)(1).ToString
Better mention this inside the for each loop as I believe you have kept NomeOutout as string variable
And just mention as NomeOutout.ToString in message box
Or
If you have kept the NomeOutout variable type as array of string then expression will be
NomeOutout = Split(item,”;”) and continue in the same way as you have now
Hello dear ppr.
Great explenation.
Let me see if I can solve it with Palaniyappan. If can’t I’ll try it in your way :wink:
My Dear!
It worked exactly how I want it.
Thank you a lot for your time.
Have a nice day
