iam facing the problem in looping the read range data ,
i cant write the data form this data table .
Hi @akshaygm12,
row("ColumnName").ToString()
Or
row(ColumnIndex).ToString()
@akshaygm12 Before forloop give writeline to check how many rows are there in that datatable. and also check whether name datatablename give both for each and read range activity.
Hey, @akshaygm12!
You don´t need customer_data_array variable.
You must have an issue with the variable type you assigned to customer_data_array variable.
In the for each input, just go with: row.ItemArray
It will work just fine.
@akshaygm12 can you please share what is the exact requirement
i want to read the data using read range in excel from E2:H2
then using loop i want to get the individual data from the loop and process those data .
Can you send the xaml file, So we can help
