Hi , I am trying to publish project and getting following error .
“Could not publish project entry point could not be found” .
tried multiple options
1.Updated all Activities.
2. tried to UN-install and install
Please suggest solution
Welcome to the UIpath Community.
Are you trying to publish Main.xaml file of the process or any other file are you publishing it.
Hi lakshman,
Thanks for your reply its Main.xaml
Thanks
Yogi
Could you please try to publish some other project and check once.
Hi @Yogi
Is the main.xaml file marked as the main file in your solution where the execution starts?
Also make sure there are no run time or debug errors
Thanks all for providing valuable input , it seems in my project.json my main.xaml file name changed to main(Autosaved).xaml , and that was causing this issue.
The issue is possible due to cross package reference in project.json or mail.xaml (or other xaml) file. One way to solve it is to create another new project and copy the activities in the old project to the new project.
If you get this error, right click on the “main” activity and make sure it is set to main (also it should appear bold)
cross Link:
Hi @Yogi,
Try the following:
Hope that works.
Cheers,
You are trying to publish a project that is NOT “main”.
You need just to select the project with mouse and set it as “Main”.
Publishing works then normally.
this worked easily thank you
Glad to help!
This works for me…!!!
