Need to understand how recovery works in Automation Suite?
Hi All,
I would like to understand, in UiPath Automation Suite (Single Node) installed in Linux Server.
How does the application and DB recovery works? is it simple as restore the files from backup tapes? Any special backup strategy or requirements from application or DB?
@Ritabrata_Ghosh,
Yes, your understanding is correct its backup and restore. Follow this documentation for back strategy.
Thanks,
Ashok :slight_smile:
@Ritabrata_Ghosh
it is a straight recovery…but because you dont have a backup server all the new data would be lost…so make sure you dont have anythign important or create a latest backup and then restore
cheers
