Need help on Split
I have an requirment,
eg: Input is : Sharan - Level and required output is Sharan, Input is : Sharan - basava - Level and required output is Sharan - basava.
I have tried using split function, but I am getting Sharan as output in first and in second I am not able to achieve Sharan - basava.
Can some one help me…
@Sharanabasava1
Try this
Str.Replace(" - Level","")
Hi @Sharanabasava1,
Heed on @Anil_G 's advice to replace the “- Level” with “” instead of Splitting the string.
Also, add .Trim to make sure that there are no white spaces left.
Str.Replace(“- Level”,“”).Trim
Happy automation!
Kenneth
HI,
FYI, another approach : if you need to split the last " - " without specific keyword, the following will work.
yourString.Substring(0,yourString.LastIndexOf(" - "))
