Need help at VB Code To enter variables PASSING STREING VARIABLE
Hi All
i am using below vb code
Sub DynamicRangeMacro(startRow As Integer, endRow As Integer, sheetName As String)
Sheets(sheetName).Range("U" & startRow & ":CK" & startRow).AutoFill Destination:=Sheets(sheetName).Range("U" & startRow & ":CK" & endRow), Type:=xlFillDefault
End Sub
and properties are in UiPath
please kindly let me know how to pass the strong sheet name
please kindly let me know how can i achuve this.
thank you!!!
@Yoichi
Do you have any error?
Hi @Yoichi
Its working now.
I want insert rows in excel and its showing code like below
Sub InsertRowsDynamic(sheetName As String, startRange As Range, numRows As Integer)
Dim ws As Worksheet
Set ws = Worksheets(sheetName)
startRange.Resize(numRows, 1).EntireRow.Insert , CopyOrigin:=xlFormatFromLeftOrAbove
End Sub
So how can i pass the variable startRange as Range type
Foe ex: if adding rows from A6 To 10 inserting rows
Will You please kindly help on this.
Thank You!!!
