# 🧠 Master Guide: UiPath Coded Agents — Practical Deep Dive for Agentic Automation (2025)
:three_o_clock: Estimated Read Time: ~10-12 minutes
:bust_in_silhouette: Target Audience:
  • UiPath CoE Leaders
  • Solution Architects
  • Automation Developers
  • AI/ML Engineers
  • Business Process Owners exploring Agentic Automation
UiPath has been rapidly expanding its Agentic Automation capabilities — moving beyond classic RPA into autonomous agents that combine:
:white_check_mark: AI Reasoning (LLMs)
:white_check_mark: RPA & API Execution
:white_check_mark: Business Context & Memory
:white_check_mark: Orchestration & Governance
:white_check_mark: Secure Enterprise-Grade Automation
At the center of this evolution: UiPath Coded Agents.
This article is your complete practical guide — explaining what Coded Agents are, when to use them, how to build them, and why they matter.
:magnifying_glass_tilted_left: What Are UiPath Coded Agents?
A Coded Agent is:
  • A fully programmable, AI-powered agent written in Python or Node.js
  • Hosted, governed, monitored inside the UiPath Automation Cloud
  • Directly integrated into UiPath’s platform (context, governance, security, toolsets)
:backhand_index_pointing_right: Think of Coded Agents as:
“Bring your own advanced AI logic — while letting UiPath handle orchestration, security, deployment, and governance.”
:key: Coded Agents vs Traditional RPA / Agent Builder
Capability Traditional RPA Agent Builder Coded Agents
Developer Skill Low-code Low-code Full-code
AI Reasoning Minimal Basic LLM Reasoning Full AI Planning / LLM Orchestration
Customization Workflow Driven Declarative Agent Setup Full Programming Control
Governance :white_check_mark: :white_check_mark: :white_check_mark:
Use Cases Standard Automation Simple AI Agents Advanced AI Agents
:building_construction: Where Coded Agents Fit Inside UiPath Agentic Automation Stack
Coded Agents are one pillar of UiPath’s agent ecosystem:
  • :white_check_mark: Low-Code Agents (drag-drop studio agents)
  • :white_check_mark: Agent Builder (low-code agentic LLM orchestration)
  • :white_check_mark: Coded Agents (fully custom reasoning + orchestration logic)
:backhand_index_pointing_right: Coded Agents give maximum control when you need:
  • Complex reasoning loops
  • Custom memory structures
  • Multiple LLM integrations
  • Advanced planning & decision trees
  • Dynamic tool discovery (MCP integration)
:wrench: How Coded Agents Work (Under the Hood)
:one: Write agent logic using the UiPath SDK (Python 3.9+ or Node.js)
:two: Integrate any LLM (OpenAI, Azure OpenAI, Anthropic, UiPath AI Fabric)
:three: Register tools dynamically via SDK
:four: Leverage memory (short-term, long-term, external memory providers)
:five: Deploy into UiPath Automation Cloud as a governed agent
:six: Observe, monitor, and control execution through UiPath governance layers
:package: What’s Included in the SDK?
  • :white_check_mark: Agent lifecycle orchestration
  • :white_check_mark: LLM orchestration utilities
  • :white_check_mark: Memory APIs (short-term + long-term state)
  • :white_check_mark: Tool registration APIs
  • :white_check_mark: Secure enterprise context injection
  • :white_check_mark: Exception handling & observability
:light_bulb: Practical Example: Refund Processing Agent (MCP Integration)
Business Problem:
Customer sends refund requests via email → agent autonomously validates → triggers refund → sends confirmation.
:hammer_and_wrench: Coded Agent Flow:
:one: Ingest request (email parsing via DU or mailbox integration)
:two: Classify intent via LLM (“Refund” vs “Inquiry” vs “New Order”)
:three: Validate refund eligibility via internal APIs
:four: Dynamically discover refund APIs via MCP Servers
:five: Trigger refund via Stripe MCP Server
:six: Send confirmation email to customer
:technologist: Python SDK Code Sample:
python
CopyEdit
from uipath_agents_sdk import Agent, Tool
class RefundAgent(Agent):
    def __init__(self):
        super().__init__()
        self.register_tool(Tool(
            name="refundTransaction",
            description="Refund customer via Stripe",
            input_schema={"transaction_id": "string", "reason": "string"},
            function=self.refund_transaction
    def refund_transaction(self, transaction_id, reason):
        stripe_mcp_client = StripeMCP(server_url, api_key)
        return stripe_mcp_client.refund(transaction_id, reason)
    def on_message(self, message):
        intent = self.llm.classify(message, labels=["refund", "payment", "other"])
        if intent == "refund":
            transaction_id = extract_transaction_id(message)
            reason = extract_reason(message)
            return self.invoke_tool("refundTransaction", transaction_id, reason)
        return "No action required."
:locked_with_key: Why Enterprise CoEs Should Care
:white_check_mark: Benefit :bar_chart: Outcome
Governance Full security, credential management, RBAC via UiPath
Scalability Build once — reuse everywhere inside platform
Observability Native logging, monitoring & troubleshooting
Tool Expansion Leverage MCP + Tooling dynamically
Hybrid AI Use multiple AI models for different reasoning tasks
:magnifying_glass_tilted_right: Troubleshooting Resources
:backhand_index_pointing_right: Official UiPath troubleshooting guide:
Common Issues To Watch:
  • Tool registration errors
  • API key management via UiPath Key Vault
  • LLM response parsing
  • Schema mismatches
  • Memory overflow in long-running tasks
:rocket: Practical Getting Started Steps
:white_check_mark: Install Python or Node.js SDK
:white_check_mark: Build simple agent locally
:white_check_mark: Test basic LLM interaction + tool registration
:white_check_mark: Deploy into Automation Cloud (Agents workspace)
:white_check_mark: Test end-to-end flows (inputs, tool calls, outputs)
:white_check_mark: Set up monitoring + error handling
:white_check_mark: Start scaling with MCP Servers and memory management
:chequered_flag: The Bigger Picture — Future of Coded Agents
UiPath Coded Agents will power:
  • Autonomous automation flows
  • Self-healing agentic workflows
  • Multi-agent orchestration (in combination with Maestro BPMN)
  • Real-time LLM decisioning
  • AI-powered process augmentation (human-in-the-loop + autonomous)
:fire: Key Takeaway
Coded Agents = Full control over AI reasoning, with UiPath governance.
Perfect for advanced, complex, business-critical AI agents that require safety, scale, and flexibility.
:megaphone: Let’s hear from you!
Have you started exploring UiPath Coded Agents? What use cases are you building?
:backhand_index_pointing_down: Drop your thoughts, questions, or challenges in the comments below.
UiPath #CodedAgents #AgenticAutomation llm #EnterpriseAI #AutomationCloud mcp tools #UiPathAgents #AutonomousAutomation python langchain #EnterpriseAutomation coe governance
