Machine learning extractor problem
hello guys!
I want to read and extract data from an invoice and, I have a problem with my machine learning extractor .
I get this error when I put this endpoint .
any suggestions please !!
Hi @youcef_bmz ,
welcome to the community
Which edition of UiPath are you using?
Thanks
Hi @youcef_bmz
Have you configured extractors ???
Kindly replace the endpoint given below and try again
https://du.uipath.com/ie/invoices
You have to use endpoints given by uipath
Look at the below link for more reference
Thanks
Robin
Now I’m receiving this warning .
I configured extractor, and I put this end point “https://du.uipath.com/ie/invoices”
Hi @youcef_bmz
Install the below and try agian
Uipath.DocumentUnderstanding.Ml.Activities
Thanks
Robin
Is your issue resolved ?
