And I want to join all columns with the same Code and Postpone, merging only the columns Reference,Code and Value . But I also want to keep the rows that are not the same.
(From d In DtBuild.AsEnumerable
Group d By k=d(2).toString.Trim, k2=d(4).ToString.Trim Into grp = Group
Let nj = String.Join(" ; ",grp.Select(Function (n) n(0).toString.Trim))
Let Value = String.Join(" ; ",grp.Select(Function (n) n(5).toString.Trim))
Let code = String.Join(" ; ",grp.Select(Function (n) n(6).toString.Trim))
Let ra = New Object(){nj,grp.First()(1),k,grp.First()(3),k2,Value,code}
Select r = DtOutput.Rows.Add(ra)).CopyToDataTable
@Gokul001 Thanks a lot man, the only thing missing is that I needed the validation to be done for lines that have the same “Reference AND Postpone”, but LINQ is joining for cases where lines that have the same “Reference OR Postpone”.
Can you tell me how to change this?
The same customer(column “Cliente”) can have more than one invoice, but those with the same Postpone will be sent in the same message. While those from different dates will be sent separately on their respective dates using Postpone on queue
Could you confirm whether the Input and Output provided is proper ? It doesn’t seem to match the conditions and also the Code Column in the Output contains 7, 8 where we cannot map it back to the Input.
Let us know the correct Output if at all the one provided was incorrect which would help us then focus on the Logic that could be used in creating the solution.
Hi @supermanPunch,
Sorry for the mistake, the wrong worksheet is the input. The column “Code” is a unique key and should have followed the order of the numbers above.
The last two lines, which have values “1” and “1” are “6” and “7” respectively
To be clearer, Could you provide us with the Input excel file, So that we could work on it and provide you with the Suggestion or an Approach to Solve the issue.
