Invoke Power Shell: The module 'reg query HKLM' could not be loaded. For more information, run 'Import-Module reg query HKLM'
I’m getting the below error as “Invoke Power Shell: The module ‘reg query HKLM’ could not be loaded. For more information, run ‘Import-Module reg query HKLM’.” while executing the below query in power shell activity.
“reg query HKLM\Software\Policies\Microsoft\Edge\ExtensionInstallForcelist /v 1”
Can you please let me know what the issue is and how can i resolve this issue.
Link
Date
2024-04-15
Related UiPath products
Studio
@narasimhappa.devulacheruv,
Add this line of code before you use it’s commands.
Thanks,
Ashok :slight_smile:
Hi Ashok,
Thank you for your response.
I tried it but still same issue. And my query is “reg query HKLM\Software\Policies\Microsoft\Edge\ExtensionInstallForcelist /v 1”
Which means do i add like “Import-Module reg query HKLM reg query HKLM\Software\Policies\Microsoft\Edge\ExtensionInstallForcelist /v 1” ?
I’m able to recreate the issue you are facing. It’s due to type of the command. It’s kind of script in it unlike of other commands like Get-Process etc.
Solution:
Just check the property IsScript like this and this will be resolved.
But you will have another error if you have kept property TypeArgument to default: System.Collections.ObjectModel.Collection<System.Management.Automation.PSObject>
Invoke Power Shell: Unable to cast object of type 'System.String' to type 'System.Collections.ObjectModel.Collection1[System.Management.Automation.PSObject]'.`
Solution to this, Change property TypeArgument to String and your Output variable should of of type:
System.Collections.ObjectModel.Collection<System.String>
Output:
Invoke Power Shell Properties
Thanks,
Hi Ashok,
Thanks for your help.
It worked now and issue got resolved.
That’s great!
Please mark my answer as solution so it will be helpful to other members as well.
Thanks,
