All i’m doing is reading an email and looking at the subject. The subject has a number in it and I’m stripping everything off the subject but the number and saving that as a variable. This would be placed in another sequence in the workflow. This work… what doesn’t is if there is no email with the keyword “reminder” in it I just want it to do the else. Which is to write nope to console, that’s just for testing.
What am I doing wrong. Teach me!! Learn me!!
Thank you for your help!
@md.ahtesham
The output pane only shows the start of the execution and the end. It’s not showing the “nope” text.
I did see the “nope” text if I had an email in the inbox that didn’t contain “Reminder” I need it to output and stop the sequence if there are no emails in the inbox.
@lakshman
I have it set to check the top 30 emails. When I have a email without “Reminder” in the inbox it will process the else side and I see “nope” in the output. I need it to stop the sequence when there are no emails in the inbox that match “Reminder”.
It seems to me you can use attended robot and activate it with keyboard shortcut or manually(the easy way), or you can use orchestrator with unattended robot to do this work in the background, eg. schedule a interval for robot to run.
But no matter which way you use, you need to notice that in the way you write the loop, it will only process the available emails at that moment, when these emails are processed, your robot’s job is done, and next time you have to start it again to handle new emails, unless you make it a regular job.
