I can’t do double click with cv click. I would very much like to learn how to do that.
Hey,
in properties of this activity you have to set click type as ‘click_double’:
It’s solved! Thank you for your quick response.
No problem
If you can, please also mark ‘solution’ option on my post.
This will make it easier for someone else to find a solution to the same problem.
Thank you and best regards
