Hello, I need to do a double click with a delay between each click.
For this I use the CV click
activity and I put the ClickType in ClickType.CLICK_DOUBLE
, but I wanted to know if there was a parameter to impose a delay between the first and the second click.
Thank you
We won’t be to include a delay between two clicks if your click type is DOUBLECLICK
Instead you can use two click activities with a delay activity in between
Use two CV Click activity and a delay activity between them with timestamp you want between two clicks
Cheers @Roxane_Crepeaux
Thank you, I’ll do that, the flow will just be a little longer
